chrisfjr83
- Feb 18, 2017
- Threads
- 1
- 2
OK recently purchased this mower used and I am not sure any of the fluids have every been changed. So I went and changed the oil and oil filter and started looking through all the manuals and it talks about changing the transmission fluid and filter but gives very little information on it. Don't know how much fluid it takes or where the drain and fill ports are located and if there is any bleeding procedures that need to be done and how so. Can someone please give me some advice with either pictures or detailed information.
