Hi, I have a mower of a buddies that won't run. He said he was mowing with it and it cut off. Could turn it over and would kind o hit but smelled flooded so I pulled the plugs, cleaned them and reinstalled. Now it Wil crank and run for about 1 second and cut off. I put my spark tester on and it seems that both cylinders lose fire once it cranks. Any ideas on what that could be? I unplugged the oil pressure senso and that didn't help but I cant remember if I need to ground the wire for it to run correctly or not. It has the 27 hp kohler
