Cyllinder filled with oil
Baran420
Thanks Mike, help is appreciated. Unfortunately that didn't help. I have carby and muffler off, completely drained oil from sump and with plug in still too much compression. Must be another cavity somewhere that is filled with oil?? Might consider removing cylinder head (if I can find a nearby gasket set)... Thanks again.
