Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2017
    Posts
    Location
    North Carolina
    Mower
    Cold start problems
    I have a 2010 John Deere Z925A mower with a 27HP Kawasaki motor. It runs great when it starts and is hot but I'm having serious problems getting to start when it sits for several hours. I have checked the fuel, cleaned the carb, replaced the float and pin etc., replaced the air filters, replaced the plugs, replaced the fuel soleniod. Will changing the oil and oil filter help in case it has gas mixed? Not sure whats left to do/
  2.
  3. #2
    Join Date
    Mar 2012
    Posts
    7,287
    Location
    Wisconsin
    Mower
    Toro
    Re: Cold start problems
    I would check and/or adjust the valve clearance. Post the engine numbers and I should be able to find you a service manual.
    This is only my opinion, and many will say it ain't worth a darn, as I'm only a retired grease monkey instructor and not a professional mechanic. Use what I post at your own risk as you know teachers only know book knowledge.
  4. #3
    Join Date
    Oct 2012
    Posts
    4
    Location
    Minnesota
    Mower
    I would check and make sure the choke is closing all the way
  5. #4
    1,000 Post Club
    Join Date
    Aug 2010
    Posts
    1,649
    Location
    150 west of tulsa
    Mower
    Murray
    My J D with a 22 hp Briggs was nearly impossible to start in the winter so I invented a primer port for an eye dropper of gasoline and it usually starts with the first compression stroke. I'm old and drive it to the mail box.
  6. #5
    Join Date
    Jan 2017
    Posts
    Location
    North Carolina
    Mower
    Quote Originally Posted by Rivets View Post
    Best I can see the engine number is FX751VA19235. It is a 2010, 27HP Kawasaki motor.
  7. #6
    Join Date
    Mar 2012
    Posts
    7,287
    Location
    Wisconsin
    Mower
    Toro
Similar Threads
  1. 22 HP Intek hard start cold
    By slapshot in forum Briggs & Stratton Forum
    Last Post: 07-21-2016, 08:15 PM
  2. Cold Start Problem
    By rope in forum Briggs & Stratton Forum
    Last Post: 06-28-2016, 04:49 PM
  3. Repairs wont start when cold
    By Mwh0428 in forum John Deere Forum
    Last Post: 01-12-2015, 02:34 PM
  4. mower won't start when cold but once its hot will start right up.
    By mackmatt in forum Small Engine & Mower Repair
    Last Post: 12-04-2014, 08:27 AM
  5. Engine JD JS46 hard cold start no warm start
    By carusoswi in forum John Deere Forum
    Last Post: 04-28-2013, 04:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
