Results 1 to 1 of 1
  1. #1
    Join Date
    Oct 2016
    Posts
    14
    Location
    Ohio
    Mower
    LawnBoy
    Duraforce oil seals
    Hi there Lawn Boy guys. I have a question about the crank seals on a Duraforce engine. Is the bottom oil seal different than the top seal? I was looking on the Lawn Boy Master parts viewer and it shows no. 4, part no 611396 for the top seal with a (2) behind it like it would take 2 of these. I know it is the same seal that works on F and V series engines. But it also shows no. 9, part no.94-5764 for a bottom seal. I wasn't sure if I needed this seal or if was for something else a little higher up on the crank shaft. Can anyone with some experience help me out with this?
    Thanks a lot.
  2.
Similar Threads
  1. Kohler ch20s leaking oil out of exhaust seals
    By AHtex in forum Kohler Engine Forum
    Last Post: 08-17-2016, 04:28 PM
  2. Do the oil seals on a briggs lawnmower engine sit flush with the housing?
    By tiresharkdbb in forum Briggs & Stratton Forum
    Last Post: 10-31-2014, 09:33 PM
  3. Cross reference for JD OEM seals.
    By AWA in forum Small Engine & Mower Repair
    Last Post: 06-09-2013, 01:16 PM
  4. f series oil seals
    By backdraft341 in forum Lawn Boy Forum
    Last Post: 10-04-2012, 10:56 AM
  5. Powerwasher lub in water seals ???????????
    By bbbobbb in forum Mower & Equipment Operation
    Last Post: 05-07-2010, 09:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
