Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Join Date
    May 2015
    Posts
    28
    Location
    Illinois
    Mower
    Tinkering Kind of Guy
    Re: LT155 w. Kohler 15.5 hp - Freaky Starting Question
    Quote Originally Posted by ILENGINE View Post
    I have seen more than one Kohler fuel pump loose prime after setting, The fuel will seep out and then the diaphragm seems to dry out and then won't pump fuel. If you can get fuel back into the pump then seem to work OK after that. Did one that way on a CH20 yesterday that had been setting for several months.
    My plan is to install a fuel shut off between the filter & pump to keep the fuel from bleeding back.
  2.
  3. #12
    Join Date
    May 2015
    Posts
    28
    Location
    Illinois
    Mower
    Quote Originally Posted by southfreedon View Post
    Installed fuel shut off but problem wasn't solved. Suggestions please?!?!?!
  4. #13
    RDA.Lawns's Avatar
    Join Date
    Jul 2016
    Posts
    382
    Location
    Texas
    Mower
    Toro John Deer Kubota
    Buy a pump. They aren't that expensive.
Similar Threads
  1. GCV160LA0 S3A Engine Not Starting Question
    By Steve L. in forum Small Engine & Mower Repair
    Last Post: 08-03-2014, 02:42 PM
  2. GCV160LA0 S3A Engine Not Starting Question
    Last Post: 07-30-2014, 08:52 PM
  3. starting question
    By thunderchris in forum Cub Cadet Forum
    Last Post: 05-04-2013, 05:36 PM
  4. Question on charging battery and backfires afterwards when starting
    By ranger1850 in forum Small Engine & Mower Repair
    Last Post: 11-06-2012, 12:19 AM
  5. Starting Question John Deere 120
    By Darrel in forum Small Engine & Mower Repair
    Last Post: 07-30-2010, 04:04 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
