Martinomon
- Dec 29, 2016
- 1
- 6
Good ideas ....thanks !
Reynoldston....sorry ....I don`t know how to use the forum yet ....this is a Briggs 18 HP Opposed Twin -80`s vintage...horizontal shaft 4 cycle........Rocky ...good info on the MC exhaust...I have 2 harleys and I know about the back firing....got mine right !....Thank you both for the info......I started messing with some pipe today and since the exhaust ports are off set , it will make it difficult to make an easy connection ...Question: is there a flexable metal(stainless steel) exhaust material out there that could be used to connect the 2 sides ...the size of the outside diameter of 3/4 gal. steel pipe? Or any suggestions ?? Thanks ~David
