Hydraulic Leak in 2014 Scag Tiger Cat w/ 30 hp B&S engine
Matt Wasdin
  • / Hydraulic Leak in 2014 Scag Tiger Cat w/ 30 hp B&S engine
Hello, I recently purchased a 2014 Scag Tiger Cat with 220 hrs. I didnt realize it has a bad hydraulic leak. I am having trouble locating the leak. I would like to locate it before taking it to be fixed. Is there a dye that I can add to the reservoir to help locate the leak? I am in Middleburg Florida. Anybody have any recommendation on a good place to have it serviced?
Thanks
Wash , degrease & blow dry the mower.
Spray all the suspect areas with spray on powder then run the mower, the leak will show up easy enough.
If you want to go one better get a couple of cans of dye penetrant crack detection developer but sit down before you ask the price.
