Greetings: I'm working on a JD 345 riding mower and having some problems with re-attaching the fuel hoses to pump/carb. It has a Kawasaki FD611V engine. I've taken pics of it prior to removing carb and pump but the pics don't show enough detail because of the dirt and other junk accumulated in the area - I've looked online for info on this but I can't find any, the fuel pump diagram shows where the pump to carb hose is located (which means the other hose nipple would be attached to fuel line from tank). Any help on this would be greatly appreciated, thanks.
