Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Join Date
    Jun 2016
    Posts
    421
    Location
    New Jersey
    Mower
    Hustler RSD 54"FR Kawi,Bobcat 48" Belt Kawi FS powered,Husky 22" RWD Honda Powered
    Re: Jacking mower from rear to store for winter
    Been cutting grass professionally for 28 years and never jacked up a mower,are you worried about flat spots on the tires??If so just roll the mower 1ft in either direction once a month.
    When I store my mowers I will treat whatever fuel there is in tank with Lucas Ethanol stabilizer,then Ill pinch off the vacuum or fuel line and run the bowl dry,then slap a tender on the battery.
    Usually make sure the oil is on the clean side but not even that.
    For my trimmers and blowers i just treated half of them with Lucas and ran it into the bowl,the other two got ran dry..this is the first time Im leaving fuel in a couple of my two strokes,Id like to see if that Lucas really works well on those type engines.
    Here in jersey we usually finish up doing out last leaf blow in December,so about 4 months off 8 on.
    I never go by any manufacturer recommendations for anything after warranty is up,,heck even before its up :)
    577 and Iím out....
  2.
  3. #12
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,650
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    The reason we store our pulling tractor tires outside in a harsh environment is to make the rubber harder so they don't flex as much when pulling. This is also the reason we always buy used tires. The only reason I can think of to jack the tires off the ground on a lawn mower to keep the rubber soft and flexible so the tires last longer over many years of use. The mower will wear out before the tires????
  4. #13
    1,000 Post Club
    7394's Avatar
    Join Date
    Sep 2014
    Posts
    1,230
    Location
    Tennessee
    Mower
    Toro Z w/Kawi
    Tire Dressings such as Armor-All will make tire rubber harder as well. Draws out the oils. But not water-based tire dressings.
    Buddy aka: Numbers
  5. #14
    RDA.Lawns's Avatar
    Join Date
    Jul 2016
    Posts
    529
    Location
    Texas
    Mower
    Toro John Deer Kubota
    Back in my race car days. I'd store my dirt track car on Jack stands under the frame. To allow the suspension to drop. With the racing shocks and the coil springs made them stay stiffer longer.
  6. #15
    Join Date
    Apr 2014
    Posts
    133
    Location
    Pennsylvania
    Mower
    Hustler Super Z Kioti DK 35 w/84" mower
    Quote Originally Posted by kraky View Post
    Seems like a ton of overkill to me. If the dang mower sits on its wheels 9 months out of the year why can't it another 3? I've never blocked a mower up in my life and never had a problem. I don't know ANYONE who does or has had a problem.
    +1
    I have never blocked a mower up over the winter. Don't really see the gain.
    I bought a 1978 Wheel Horse garden tractor used back in 1986. Still have it, never been blocked up for decades with no issues.
    Hustler Super Z
    Kioti DK 35
  7. #16
    Join Date
    Jul 2015
    Posts
    32
    Location
    Florida
    Mower
    Hustler Fastrak 54
    Asked this same question in the past with the manual stating to "Store for long term" blah, blah......
    You know what I ended up doing was just to start it up and let it heat up for a few minutes and move it out into the drive way then back in the garage. I did it about every 2 to 4 weeks. Probably not necessary after all but made me feel better.
    For me its only a mild Florida winter all of about 3 months. I just like to keep things running and not to sit too long.
  8. #17
    Datadave's Avatar
    Join Date
    Jul 2016
    Posts
    70
    Location
    NE Florida
    Mower
    Hustler RSD 54"
    Quote Originally Posted by Grass Whisper View Post
    Same here
    I use mine to pull a utility trailer around during the off season which is short here in Florida
  9. #18
    RDA.Lawns's Avatar
    Join Date
    Jul 2016
    Posts
    529
    Location
    Texas
    Mower
    My stuff may get a month max of no use. I just park it all in the shop and forget it .
  10. #19
    Join Date
    Aug 2015
    Posts
    910
    Location
    Kansas
    Mower
    Toro/Cub Cadet/Kubota
    I have a Woods 660 rear mount mower.
    Believe it or not, I have taken to resting it on blocks to keep weight off the semi-pneumatic tires because they WERE getting flat spots.
Similar Threads
  1. Troy built XP 21" rear bagger rear wheel drive mower
    By brother electro in forum Troy-Bilt Forum
    Last Post: 06-24-2015, 11:54 AM
  2. Buying Advice Western Auto Mower/Parts Store
    By WesternAuto in forum Mower & Equipment Operation
    Last Post: 08-27-2013, 02:28 PM
  3. Mower Winter Storage
    By jmurray01 in forum Polls
    Last Post: 02-23-2012, 06:20 PM
  4. Starting a mower after winter
    By MotorDuck1 in forum Small Engine & Mower Repair
    Last Post: 04-17-2011, 11:10 PM
  5. Why shouldn't we store gas over winter?
    By adan in forum Lawn Care & Landscaping
    Last Post: 12-21-2010, 04:10 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
