Having difficulty getting starter to engage on Kohler 15HP engine in JD LX173. There is definite click when key is turned but starter does not engage. After numerous attempts (and clicks) the starter will engage and crank just fine till engine starts.
Battery and connections are good. Any suggestion before I simply replace parts?
MM
MM
