The Daily Yardman Thread
Boobala
Re: MTD Yardman Transaxle Rebuild
Well then, at least COMPREHENSION isn't the problem............
I musta suffered another A.D.D. episode .......... Always Directly Distracted ! ..:laughing:..:laughing:
BlazNT
I pulled my head out of the deep,dark recess in which it had been thru this cold snap today.
I had had a water valve (Chinese PVC ball valve leaking at the stem) that I had to dig up
and replace.
I replaced with a bronze ball valve which required thread to socket adapters to be threaded into each end.
With the threads dry, the adapters threaded right in.
When sealant was applies, I couldn't get those *#@%&**! things in straight!
Had to remove pipe dope from last 2 threads in order to get them in straight!
NEVER had that happen B-4.
Got 'er done,tho.
So far, so good.............
Plastic to brass?
Ronno6
I thought A.D.D stood for Anal Dandruff Depository.
BlazNT
BlazNT
The "Bean Counter" has arrived. Let the party get started.
I went outside this morning without my coat. It is going to be a beautiful day. 49 at 3:50 AM
BlazNT
Morning Boo.
Boobala
GOOD Mornin Gang !
Good-Morning-Memes-2-1.jpg .... Well now that it's warming up, we can worry about the flooding, hope everybody's preppin to move to higher ground !
