- Nov 29, 2014
- Threads
- 64
- 24,702
Re: MTD Yardman Transaxle Rebuild
Gets difficult as kerro can be totally different things in different places.
Power kerro down here is also Jet 1 fuel and clear
Highly refined heating / houshold kerro is died blue and is low/no sulphur.
Slightly less refined lighting kerro is died yellow and contains sulphur
Using any of them indoors is not a good idea as careless handleing of them results in you standing out side your burning house wrapped in an emergency blanket.
Using low grade kerro can be made acceptiable by boiling water on the heater so the exhaust & water vapour mix.
The water adsorbs the compounds in the exhaust , but of course will deposit them on the inside of your windows or any other condensing surface.
