Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    smullen's Avatar
    Join Date
    Oct 2016
    Posts
    Location
    Missouri
    Mower
    Hustler Raptor
    Re: Hustler Raptor 52" Model # 933077 Deck Issue, Bolt/Mount Broke, Deck dropped.
    Another thing I'll warn about is the soft deck metal...
    Twice now, either me or my G/F have been backing out of the shed and down a plywood ramp, when we did so, the decks seems to have gotten High centered (even in the all the way up position) and bent the round metal that the blades spin in.
    Then when we turned on the blades, it clattered like all hell was breaking lose...
    I had put it up on ramps and crawl under it with vice-grips and big pliers to bend the metal back out, so the blades would clear...
    That was at the beginning of the summer, since then, I've been putting it in the garage to prevent that... I guess I need to build a better or not as steep ramp.
    Its just a 4x8 sheet of plywood, cut down a bit, turned length ways and laid down so I can drive the Mower or ATV in and out of the shed.
    I'm limited on ramp options as the dang shed doors hang down about 4" lower than the actual floor, I guess to help seal out the winter and look nicer too... Anyway, if I build a permanent ramp there, the sheds doors would hit when I open or close them... Thanks why I just lay that plywood in there till I get whatever in or out...
  2.
  3. #12
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    5,405
    Location
    Missouri
    Mower
    RZ5424
    When I get home I will get you a couple of good pictures of what I did for my shed ramp.
    Chuck
    We Do Not Stop Playing When We Grow Old
    We Grow Old If We Stop Playing
  4. #13
    smullen's Avatar
    Join Date
    Oct 2016
    Posts
    Location
    Missouri
    Mower
    Hustler Raptor
    Quote Originally Posted by BlazNT View Post
    Thank ya again sir....
    Dang this place is handy...
    I've been on other forums where all they do is talk smack too or about each other.... This place is helpful and all about solutions!!!
    Good folks from everything I see...
  5. #14
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    5,405
    Location
    Missouri
    Mower
    RZ5424
    Oh we get some smack on here too but try to keep it to a minimum.
    Chuck
  6. #15
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    5,405
    Location
    Missouri
    Mower
    RZ5424
    Sorry for the late post.
    First I attached a straight ramp to the underneath of the shed drilled holes through the shed floor into the ramps 6" carrage bolts to attach.. I finished off with 3/4 treated plywood.
    Chuck
  7. #16
    Join Date
    Mar 2017
    Posts
    Location
    Illinois
    Mower
    Looking to Buy :)
    I have the same mower. Same bolt broke. I found this thread looking for the same info you were looking for. Thanks for answering questions. I think Hustler has a bit of a design flaw here. It doesn't seem like this bolt should ever be a problem.
  8. #17
    Mr. Mower's Avatar
    Join Date
    Sep 2016
    Posts
    79
    Location
    Texas
    Mower
    Hustler Raptor Flip-Up
    My owners manual informs the user to follow a daily or weekly checklist, to inspect, making sure that all hose's are tightly secured and all bolts are tightened.
    Even though most us probably don't actually do this on either a daily or weekly basis, still it is good practice to at least give it consideration and perform this task at least once a month maybe?
    You never know, you just might come across lose or un-tightened bolts, which over a period of time using the mower can happen.
    On my old mower I experienced this first hand. From time to time I would find lose bolts, missing nut, etc., so I found this out first hand.
    Over all, very good info here on Hustler mowers.
  9. #18
    Join Date
    Oct 2016
    Posts
    24
    Location
    United States
    Mower
    Hustler Raptor SD54, John Deere 100
    Quote Originally Posted by Mr. Mower View Post
    They also know a very small percent actually read and follow that advice. That is just the lawyers covering their a.
    I've got seat arms that will not stay tight no matter what. Poor design. Tighten them up and they don't move. Then again, I think they are too low anyway but that's another story.
  10. #19
    Join Date
    Apr 2017
    Posts
    Location
    Virginia
    Mower
    Hustler Raptor
    Well, I found this forum because my deck bolt broke, too. Does anyone know if you can just purchase a bolt or if you have to get the whole deck pivot kit. I see Hustler has the kit online for $38.95. I'd rather not pay that much for complete kit when I just need the bolt.
    I think I may need a support group for this mower. This is the 4th season I've it. Each year (in April), the drive belt breaks. It has broken 3 times! I contacted Hustler last time, and they spoke with the dealer and gave them a different fix for the belt. So, hopefully this year it won't break. Maybe, just maybe, this freaking bolt will be my only issue this year. I sure hope so!
    Thanks for the information in this thread/ forum.
    -Todd
  11. #20
    Join Date
    Apr 2017
    Posts
    Location
    Tennessee
    Mower
    Hustler Raptor 52 inch
    Thanks guys for all the great info, new to this forum. my deck bolt broke and i was under warranty but nearest dealer is 35 min away from my home and I had no real way to transport my mower. Ordered new deck bolt kit from the link that was on the forum and it got to me in 2 days. mower back up and running . that new part is alot more heavy duty, so hopefully wont have anymore issues with that breaking. Bought mower from Lowes and they wont touch it unless you bought extended warranty from them. Lowes you suck.
Similar Threads
  1. Hustler Raptor Limited 52" Deck Adjsutment
    By braves9822 in forum Hustler Forum
    Last Post: 03-08-2017, 03:07 PM
  2. Hustler Raptor 933077 Fan/Pulley Kit
    By Evans35173 in forum Hustler Forum
    Last Post: 09-26-2016, 11:18 AM
  3. Replies: 3
    Last Post: 09-10-2016, 08:41 PM
  4. Hustler Raptor Deck jump
    By Jake Longnecker in forum Hustler Forum
    Last Post: 09-07-2015, 08:13 PM
  5. Mower deck Can you mount a 42" mower deck on a D324?
    By phofman in forum John Deere Forum
    Last Post: 07-20-2013, 09:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
