Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2014
    Posts
    Location
    Midlothian, TX
    Mower
    Hustler Raptor SD 54"
    Raptor SD deck will not go lower than 3" setting
    I've been having an issue with my SD and cannot figure out how to fix it. The mower is a 54" SD with 50 hours on it. A month or so ago I noticed that the lowest I can set the deck to is the 3" setting. Anything lower than that actually sets it higher than the 3" setting. Anyone else ever had this issue?
  2.
  3. #2
    2,500 Post Club
    Join Date
    Jul 2013
    Posts
    4,212
    Location
    Georgia
    Mower
    2010 simplicity broadmoor 46" deck 20hp vanguard
    Re: Raptor SD deck will not go lower than 3" setting
    Still under warranty, do not mess with it, take back to dealer.
  4. #3
    Join Date
    Jul 2016
    Posts
    42
    Location
    Texas
    Mower
    Huster Raptor SD 54
    Not sure, mine will go all the way down until the deck floats on top of the ground and the rod will ride up and down in the bracket.
  5. #4
    Join Date
    Oct 2016
    Posts
    24
    Location
    United States
    Mower
    Hustler Raptor SD54, John Deere 100
    Are you sure you are lifting up on the little chrome handle that holds it up for travel? I never use it except for loading on a trailer... so, once.
    (I don't see the point of it but what ever.)
    I needed I can shot a vid of it... I'm not sure what the handle is called.
  6. #5
    Join Date
    Jun 2015
    Posts
    205
    Location
    Midwest
    Mower
    hustler raptor sd 54
    are you pulling the pin out? lol
  7. #6
    Join Date
    Jun 2015
    Posts
    341
    Location
    Wisconsin
    Mower
    Fastrak 54
    Is your foot under there? OK this is getting sad...lol
  8. #7
    RhettWS's Avatar
    Join Date
    Dec 2015
    Posts
    145
    Location
    Louisiana
    Mower
    Hustler RSD 54"
    Not sure whatever happened with the OP. Sound like he thinks the lower the pin, the lower the deck setting. It is actually opposite. The closer the pin is to the ground the higher the deck is. Frankly, the first time I fiddled with it, I made the same mistake. Since there are no measured height settings, one would intuitively think the lower the pin (towards the ground), the lower the deck would be.
Similar Threads
  1. Hustler Raptor Limited 52" Deck Adjsutment
    By braves9822 in forum Hustler Forum
    Last Post: 03-08-2017, 03:07 PM
  2. Deck Clutch Switch - Raptor 52"
    By Sturno in forum Hustler Forum
    Last Post: 07-06-2016, 12:11 PM
  3. Replies: 18
    Last Post: 05-14-2016, 05:17 AM
  4. One blade on my deck cuts lower than the other two
    By Stanley-O in forum Murray Forum
    Last Post: 03-25-2016, 05:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
