Depends on how long the water was in there and if it was ran with water in it.
Do not start. Drain. Refill with new oil using part seafoam. Start, let run for a while, drain and refill with new oil again . Start, listen for anything that doesn't sound normal.
Also, if the tiller was where it could get water in the engine, you may have other problems, check the spark.
