Results 1 to 2 of 2
  1. #1
    Join Date
    Jun 2011
    Posts
    Location
    New York
    Mower
    Lawn Chief
    Question Toro 6.5 hp Recycler will not self propel
    I have a Toro recycler with a Tecumseh 6.5 hp engine that a friend of mine gave to me the other day. He told me that it ran good but suddenly would not start. I looked around and then found that the flywheel key was sheared so i got a new one and the mower runs good. It doesn't vibrate indicating a bent or loose crankshaft or connecting rod but if you push the lever down for the self propelled it doesn't move. The gears inside the wheels are fine and if you move the pulley the wheels do spin. I took the cover off where the belt is and had it running and when you push down the bar the belt doesn't move. I thought the belt was old so got a new one and it still doesn't work. I also tried adjusting the cable but it still does nothing... Any suggestions?
  2.
  3. #2
    rmancini's Avatar
    Join Date
    May 2010
    Posts
    134
    Location
    Western Washington
    Mower
    JD LX277, JD 790 loader, Cub Cadet Z Force L48 & Cyclone Rake
    Re: Toro 6.5 hp Recycler will not self propel
    Although the drive gears look like they are okay, it doesn't take much wear for them to cease to function.
    I recently ran into that very problem on a friend's machine. There were also some transmission issues.
    Another thing to consider is that the cable that connects the transmission to the handle is not working properly (frozen in-place or disconnected).
    I have a Toro manual with a pretty decent section on transmission repairs. It's in a PDF format.
    I'd be glad to email it to you. Just let me know if you want it and where to send it.
    Rich
Similar Threads
  1. Toro 22in Recycler mower - engine cuts out
    By drumsab in forum Toro/Wheelhorse Forum
    Last Post: 05-26-2014, 12:54 PM
  2. Which? Toro Super Recycler B&S (20029) or Kohler (20099)
    By wjm in forum Mower & Equipment Buying & Pricing
    Last Post: 09-09-2013, 10:20 AM
  3. toro recycler
    By nova in forum Toro/Wheelhorse Forum
    Last Post: 06-14-2011, 02:05 PM
  4. Toro self propel problem
    By wwall10383 in forum Toro/Wheelhorse Forum
    Last Post: 05-13-2011, 10:22 AM
  5. Just got my Toro Super Recycler!
    By Grass ala Mowed in forum Mower & Equipment Buying & Pricing
    Last Post: 03-19-2011, 05:51 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
