Hello,
I'm trying to figure out a little about a mower I recently purchased. It's an HRM215-EG according to the plate on the deck. Other identifiers I've found are :" MZBB-6140577" "SDA *"
The engine's serial is GJAB-6614378.
When I search for parts I don't usually see anything with the "EG" or any of the MZB within the 6140577 range. I need to get some parts for it, blades, air filters, misc screws and I just want to make sure I get the correct ones the first time!
Bought the mower for $10 not running, tried cleaning carb but no go, replaced carb and off it went! I look to have less than $100 invested in it by the time it's fully running/maintained so I'm very happy with that!
Any advice as to which model to select when I search for parts? Also if you have any information about the mower it would be greatly appreciated!
Thanks!
Thanks!
