cruzenmike
- Feb 10, 2017
- Threads
- 57
- 852
Re: Known major problems; Kohler 7000, Kawasaki FR, Briggs & Stratton Commercial . .
You just cannot find anything under $3500 with serviceable hydrostatics and even at that price they would be ZT-2800s. I think this engine would be great, but maybe greater in a different make or model. If you read the online reviews of this exact mower, most give the engine praise over anything else. I would think a great mower would be great with any engine (Kaw, Briggs, Kohler, etc.) so long as it wasn't underpowered. But a really good engine alone cannot make an average mower great. At the end of the day, each person has to choose what is most important, engine, deck style, features, BTS, and so on. I think a 22-24 HP of most any newer v-twins are going to work just fine for most consumers if properly maintained. Little things like reading the ENGINE'S operators manual and not just the mowers will provide some insight into how to maintain based on the manufacturer who actually designed and engineered the engine. For example, I have seen in operators manuals where it says to reduce the engine to minimum throttle and let idle for at least 30 seconds before shutting the engine off. Who does this?
I gave it a "once over" and only thing I didn't like about that set up was the 2200 hundred series transmissions. I'd pay more $ for 3400's if they were available. Other then that...I liked it!
