Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2016
    Posts
    Location
    Pennsylvania
    Mower
    Black and Decker
    cm1936 battery fuse
    Hello. I melted the wire fuse between the 12v batteries on my 36v mower. Batteries still test good. Anyone know what value I should use in a replacement fuse?
  2.
  3. #2
    2,500 Post Club
    Join Date
    Jul 2013
    Posts
    4,199
    Location
    Georgia
    Mower
    2010 simplicity broadmoor 46" deck 20hp vanguard
    Re: cm1936 battery fuse
  4. #3
    Join Date
    Aug 2016
    Posts
    Location
    Pennsylvania
    Mower
    Black and Decker
    Hi. This is not really a reply to my query. I received the same response from B&D - a reference to their manual - which is why I posted here. Inside the 36v battery are three 12v 12ah batteries connected in series with wires, one of which is a "fused" wire designed to melt if it sees too much amperage (like if wires got crossed) so the batteries do not overheat or explode. My wire melted due to severe overstress of the motor. The batteries all test as good. So I need to install a new "fuse," and want to make sure it is not too small - burns out all the time - or too large - batteries explode if the wires short. I could find this by trial and error and keep putting in increasingly larger fuses. But if anyone knows the answer to this query it would solve the issue for me.
    This information is not in any manual I have been able to find online.
    Thanks.
Similar Threads
  1. Is CM1936 "the" replacement for CMM1200?
    By Rav in forum Black & Decker Forum
    Last Post: 06-15-2014, 05:52 PM
  2. Repairs LX277 Yellow Battery Charging light staying on, battery is fine
    By JDglider in forum John Deere Forum
    Last Post: 04-06-2014, 11:53 AM
  3. HD GT2544 blows 25amp fuse on the battery circuit
    By earlyj in forum Small Engine & Mower Repair
    Last Post: 08-15-2013, 08:05 PM
  4. Are you know that Black & Decker CM1936 Best than Black & Decker SPCM1936
    By lawnmowerleader in forum Black & Decker Forum
    Last Post: 01-16-2013, 09:34 PM
  5. John Deere 185 Hydro/new battery, acts like its a dead battery
    By jordan_fehlman in forum John Deere Forum
    Last Post: 07-02-2012, 06:58 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
