Results 1 to 5 of 5
  1. #1
    Join Date
    Jun 2011
    Posts
    Location
    Illinois
    Mower
    Question 2010 Zero Turn Z-Force Cub Cadet HELP
    Hi, I don't know anything about lawnmower repair, 10 minutes ago I was mowing and the mower just stopped. no noise no smoke. The engine still runs fine but the when I pull the PTO button there is just one little click noise. please help! What could be the problem? Can I fix it?
  2.
  3. #2
    Join Date
    Jun 2011
    Posts
    Location
    Illinois
    Mower
    Re: 2010 Zero Turn Z-Force Cub Cadet HELP
    Quote Originally Posted by skittles View Post
    Okay, I just found the problem. the black band is off. Does anyone know how to put it back on? Can I do it myself? Its not broken, I just don't know what pattern to do
  4. #3
    Join Date
    May 2011
    Posts
    14
    Location
    United Kingdom
    Mower
    Ferris
    Generally when a belt comes off, more often than not, they can be fixed. I'm not sure about your particular machine, but on the zero turn machines I have owned, the machine normally has a pulley which is tensioned by a spring. If you pull the pulley back, you should then be able to get your belt onto the main pulleys. Just make sure you get the belt on in the correct position, some machines have quite a complicated pulley arrangement, ideally checked your manual before replacing the belt.
  5. #4
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Can I do it myself?
    Most likely you will be able to do it...
    Is it the PTO drive belt? or the deck belt??
    Do you have the owners manual ... it should show how to install the belt.
    If you have no manual, you can find inf here... Powered by Google Docs
    You will find the belt lay out ... KennyV
  6. #5
    5,000 Post Club
    Ric's Avatar
    Join Date
    May 2010
    Posts
    5,769
    Location
    Florida
    Mower
    Toro Grandstand 36", Toro Z-Master 2000 48" Toro TurfMaster 30"
    First off what Z Force do you have? Is it a Fabricated deck or a stamped deck. The Z Force has three different belts a Drive, a PTO and a Deck belt. You say it just stopped, did the blades stop or did the mower stop. What ever belt came off I would replace it with a new belt, I wouldn't put the old back on because there is a reason it came off and it will most likely do the same thing again.
    To replace either the deck belt or pto belt Place the deck in the lowest position, You can reduce the tension on the deck and pto belts by using the idler arm lever, from there you'll need to shift the deck forward until the trailing link is free and you be able to remove the deck if needed, other wise when you remove the pressure with the trailing link you can reinstall the pto belt. Pull of the pulley covers and you can replace the deck belt. If it's the drive belt take the thing to the shop because they're a pain in the *****.
    G &G Lawn Care
    I have the right "NOT" to be tolerant of others because they are different, weird, or tick me off.
    The more People I meet, The more I Love My Dogs
Similar Threads
  1. Cub Cadet Z-Force 60 Deck is Uneven - Need Help
    By bandman in forum Small Engine & Mower Repair
    Last Post: 06-19-2013, 07:20 PM
  2. My cub cadet zero turn doesn't turn as sharp as it used to...
    By jmasterson0013 in forum Small Engine & Mower Repair
    Last Post: 07-30-2012, 10:46 AM
  3. Cub cadet
    By DonBrasco in forum Cub Cadet Forum
    Last Post: 06-02-2011, 07:31 AM
  4. zero turn cub cadet
    By jpl in forum Cub Cadet Forum
    Last Post: 05-07-2011, 05:24 PM
  5. zero turn Cub cadet
    By Low Mow in forum Cub Cadet Forum
    Last Post: 03-25-2011, 02:07 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
