ken_clifton
- Jul 29, 2016
- Threads
- 4
- 34
The metal covered air filter project for the Briggs Intek finally went on today.
I am sure a canister system is probably much better, but this project is designed to work with standard inexpensive automotive filters. Besides, it brings back fond memories of my Kohler round air filters .
For the changes made to the Intek 44's intake system see this thread: http://www.lawnmowerforum.com/showthread.php/38437-Off-With-the-Intek-Plastic
On top of the EC Carburetors 4040 air elbow I have an aluminum 2.5 round adapter made by Al at Performance V-twins (http://www.performancevtwins.com/)
I ran an AEM brute-force dry clamp-on filter for most of the summer, but I wanted the finer filtration and the inexpensive round automotive paper filters when possible.
EMPI makes a nice spun-aluminum covered air cleaner (EMPI 9001) intended for VW bugs with a 2 5/8 round outlet. The cover looks like it would do a good job of protecting the air filter from brush when mowing.
I used a standard 2.5 inch rubber coupler hose and two #44 line clamps to adapt the round adapter on the elbow to the EMPI air cleaner. The non-reinforced rubber coupler is flexible enough to stretch over the 2 5/8 outlet of the air cleaner and also fits the 2.5 inch adapter well.
The EMPI 9001 air cleaner comes with a cotton gauze filter element. My preference is a good automotive paper filter. I spent some time looking through air filter catalogs. The WIX 42055 is a nice fit, it is rated at much more flow than the Intek will need.
A foam wrap is available, the WIX 24708. I put one on, but with the K&N filter wrap on the outside, I am not sure how much benefit is gained with the foam pre-cleaner.
Here is another photo of the whole assembly, the air cleaner does not block the air going into the blower at all -- it's edge is about 1/2 outside that area. Also, the back of the air cleaner is just inside the rear bumper on the SCAG - hopefully protected from bumps unless I back under something...
One final shot with the K&N 22-8001PK Air Filter Wrap to prolong the filter life. They really help keep the larger particles out of the filter.
Maybe someone else can use this combination on another application.
ken_clifton
ken_clifton
