Hi everyone,
I have a HRX217TDA that I've been refurbishing back to life the past few weeks. The only remaining issue I see on the mower is that it only goes one speed even though you can freely move the cable between the 3-speed settings. I tried adjusting the cable on the throttle handle but unfortunately it didn't make much of a difference.
When I flipped over the mower and traced the cable to the transmission, I noticed it is in bad shape. The outer sheath of the cable has worn off completely and the cable itself looks like it's starting to unwind. I have no problem replacing the cable, but I can't find anything regarding how the cable is supposed to attach to the transmission. I don't want to have to remove the entire transmission to replace the cable, but I know I have to remove the bottom shutter to better access the transmission.
Does anyone have any docs or photos out there to help with the positioning of how the cable is supposed to attach to the transmission? This isn't the clutch cable but the speed adjustment cable for the transmission. I've found that the clutch cable just clips to a part on the transmission but the speed cable looks like it's not the same attachment.
Thanks in advance for the help!
