Results 1 to 8 of 8
  1. #1
    Join Date
    Jun 2011
    Posts
    Location
    Arkansas
    Mower
    Troy-Bilt
    mower leaving random uncut sprigs of grass
    I've got a newly sharpened blade on a push mower for my Bermuda grass. Every 3-6 feet its leaving single strands of (6-8") long runners uncut pulled high above the cut grass. Any idea what is causing these sprigs to not get cut? Its unsightly and even a tripping hazard for my toddlers.
  2.
  3. #2
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Re: mower leaving random uncut sprigs of grass
    Welcome to LawnMowerForum...
    Is the blade mounted upside down?
    it happens... KennyV
  4. #3
    2,500 Post Club
    JDgreen's Avatar
    Join Date
    May 2010
    Posts
    2,887
    Location
    Michigan
    Mower
    Too many, running or not
    Quote Originally Posted by cadronboy View Post
    I have found if you let grass get high enough, the front edge of the mower deck will bend the grass over and depending on the speed of your push mower, grass may not be cut as short in some areas. Not sure if yours is a self propelled or not, but try going over the tall stuff very slowly and at maximum cutting height to see what happens. Although KennyV suggests your blade may be upside down, I think you would see a lot more uncut grass if that were the case.
    "I didn't plan to do anything today, but by noon I was almost half done...."
  5. #4
    Join Date
    Jun 2011
    Posts
    18
    Location
    California
    Mower
    MTD - Huskee (tractor supply co)
    I've also noticed, that if your gas is a bit damp, the wheels of the mower can push down the grass and the grass won't 'rebound' up fast enough in order to get cut. The more damp the grass is, the worse the scenario. Yeah, I know, we shouldn't cut damp or wet grass, but it happens right!
  6. #5
    Join Date
    May 2010
    Posts
    5,447
    Location
    Mower
    CTL
    Hope you are still with us...
    There are some that don't have Bermuda grass and will not realize what you are referring to... It is not the blades of grass that your talking about, buy rather the runners, that root in and have green grass on them...
    The only time I have seen these get pulled loose are when you drag something over it... When it is caught it will pull up the runner... If you have a worn skid or a bad anti scalping wheel... or the blade installed up side down... Post back with what you find...
    I love Bermuda grass and have a lot of it... Hope you get yours in check. KennyV
  7. #6
    5,000 Post Club
    Ric's Avatar
    Join Date
    May 2010
    Posts
    5,751
    Location
    Florida
    Mower
    Toro Grandstand 36", Toro Z-Master 2000 48" Toro TurfMaster 30"
    Can I ask, just out of curiosity what type of mower you have??
    G &G Lawn Care
    I have the right "NOT" to be tolerant of others because they are different, weird, or tick me off.
    The more People I meet, The more I Love My Dogs
  8. #7
    Join Date
    Sep 2013
    Posts
    Location
    Alabama
    Mower
    sears
    do you mean Bayaha grass.. it has a tall seed stem with 3 seed branches on the end.. I've found no way to correct this other than mow before they get tall
  9. #8
    2,500 Post Club
    Fish's Avatar
    Join Date
    Aug 2013
    Posts
    3,230
    Location
    Kentucky
    Mower
    I Don't Own a Mower :(
    Those toddlers are going to be in for a real shock when they hit the real world......
Similar Threads
  1. Mower deck mower deck will not go back on help grass is long
    By brianharris9 in forum MTD Forum
    Last Post: 05-04-2011, 04:15 AM
  2. My riding mower died on me when I was cutting the grass.
    By hoopstar in forum Mower & Equipment Operation
    Last Post: 04-25-2011, 08:18 PM
  3. Snapper not cutting grass good leaves sprigs
    By ghyman09 in forum Snapper Forum
    Last Post: 04-24-2011, 05:26 PM
  4. Mowing the grass before a grass party
    By minkyung in forum Lawn Care & Landscaping
    Last Post: 11-30-2010, 04:09 PM
  5. mower scalps grass
    By Hoss in forum Mower & Equipment Operation
    Last Post: 09-22-2010, 05:52 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
