Hello,
I have a Cub 2135 that I am struggling to solve a belt issue on, I have owned it for years and it has been a great tractor. Starting this year the PTO belt has started vibrating and jumping off the deck pulley frequently. I have replaced the belt, the tension springs, the bushings on the deck idler arm and still having issues. The pulleys all move well, no noise or wobble. With the deck in the highest position, the belt does not vibrate, the lower you go the more it vibrates. At 3/4 it will jump off the pulley. I have a shorter belt from another Cub I own and it helps a little but still a lot of vibration. The deck is pretty level but I am starting to think the front to back adjustment needs some work since the belt runs okay at the highest setting, can any provide the deck leveling procedure for the 2135?
Any other ideas?
Any other ideas?
