- Nov 29, 2014
- Threads
- 64
- 24,705
Only coils for use on a points ignition can be reliably tested with an Ohm meter due to the chip.
A lot of shaved monkeys why learned how to work a video camera put all sorts of junk on the web.
The kit you need to test an ignition module is a bit north of a grand down here so an inline tester on a coil with the kill wire disconnected will do for me.
No one has ever complained and every time I have replaced a coil the engine has worked well after .
