here's a few of the things i've done to my raptor.
2015 model with around 90 hours
1. cut the deck opening bigger. got rid of the angled part. also removed belt guards so grass dont build up underneath. notice the oregon gator blades, they work the best in my opinion for taller or wet grass.
2. replace these pins with the newer design that has the clips. newer raptors come with this. have knocked my deck off a couple times hitting stumps. this should stop that.
3. drilled pin for a cotter pin. kept bouncing out.
4. engine guard. looks way better.
anything else you guys have done?
