Hi Lift Jack For Zero Turn and Tractors.......
577jersey
Great little jack I wanted to share for under $100,a must for all you tractor and zero turn guys!!!!
Ric
Nice jack, I look at something very much like that jack at TSC but purchased the MoJack EZ instead. I personally don't trust the hydraulic jack part. The MoJack also features a screw jack and safety-lock pin system and it's all fully adjustable but when your finished It's made to take down and hang it on the wall, that's what I like about it.
http://www.themojack.com/products/mower-lifts
577jersey
Very cool,that jack looks alot heavier than mine!!,,yeah this Hustler is not the heaviest thing around so I figured the jack from HF would suit me just fine,,Im not sure if I would trust it on a really big heavy commercial mower with a 60-72" deck...I guess it would be fine but I would use safety stands also :)
Ric
Yeah your hustler is not the heaviest thing around but as far as that goes most mowers/ztr's aren't real heavy anyway. Your not really lifting anything more than the deck and front wheels on most of them, all the weight is in the back portion of the mower. That's the reason I went with the EZ. Like yours it has a 300 pd lift capacity which is plenty. I use it on the Toro Z Master and the Grandstand both and have no issues. I also purchased mine from TSC for $99.99 when they were on sale.
577jersey
Thats a great deal on that lift!!
If something ever happens to mine Ill try that one next :)
