New to the forum
andrew3231
Hey guys im new here and im starting up a lawn care company and right now all i have is a pish mower and a trimmer. The mower is a black max self propelled mower that has these little handy wheels on the front very similar to zero turn wheels to be able to cut around trees. My trimmer is a new Stihl Fs 90 trimer. I was wondering if anyone had any suggestions on equipment that i should also have. I am looking to purchase a blower soon but im not sure whether to wait it out until i can buy a back pack model or if i should just get a hand held to start out with? Any suggestions are greatly appreciated!
Ric
I don't know what type of business your starting or what type of service's you will be offering but that would make a difference in what equipment one would tell you to purchase. Personally I'd wait until I could get a back pack blower. Hand held are nice but nearly as effective as a good back pack but again it all depends on what you'll be clearing with the blower. Who's your mower made by, what your describing sounds like a mower with a caster front end.
andrew3231
Currently i am targeting the residential market so there will not be a whole lot of clearing needed but i plan to move up to doing commercial properties. The mower is made by black max and it is the one with the casters on the front. I included a picture of what it looks like
andrew3231
I will at first be offering just lawn mowing and weeding planted areas for now but i do plan to expand later on
:welcome:
Starting small and I gather self funding look at used gear on Craigs list, Evilbay etc.
Next piece of kit you might look at an edge trimmer with a solid blade then learn to cut clean, sharp, strait, edges.
Every day when your customes leave for work they will see your sharp clean cut edge along their section of the sidewalk or curb then the pixie fringe of their neighbours edges cut with a weed wacker and feet like they got good value.
Catherine
LawnWorld Support
Staff member
:welcome:
It sounds like an exciting endeavor.
I'm going to move your thread over to our commercial and residential lawn mowing section. :smile:
Ric
I thought it was a Honda, I had the Black max at one time but it wasn't the caster front end.
You don't give us a location so I don't know where your at and what type property's you will be doing but we do only residential and areas that contain a lot of drive and sidewalk areas. By clearing I meant blowing off your driveways, sidewalks, patios and front door area etc. Unless your going for the mow and go type of business your standard Package Services should include Mowing, Trimming, Edging and Blowing Off. Add things like Hedge trimming, flower bed cleaning maybe mulching flowerbeds etc all at additional cost. What will you be charging for a lawn?
andrew3231
I thought it was a Honda, I had the Black max at one time but it wasn't the caster front end. You don't give us a location so I don't know where your at and what type property's you will be doing but we do only residential and areas that contain a lot of drive and sidewalk areas. By clearing I meant blowing off your driveways, sidewalks, patios and front door area etc. Unless your going for the mow and go type of business your standard Package Services should include Mowing, Trimming, Edging and Blowing Off. Add things like Hedge trimming, flower bed cleaning maybe mulching flowerbeds etc all at additional cost. What will you be charging for a lawn?
i will most likely be charging around 35 or 40 for lawns because of the average lawn size i am in springfield illinois so there is a bunch of subdivisions around here with smalleer lawns
jekjr
If you are starting small like that a hand held blower will more than likely do what you need. We have backpacks and a hand held. We use the hand held more than the back packs on most residential properties. A set of hedge trimmers would make you some money. Instead of buying just an edger you might look at buying a split pole unit where you can add attachments to it. We now use the Echo PAS system and have 4 units. You can use them for string trimmer, edger, hedge trimer, pole saw........ and use the same power head to run all.
Crnbinder
Stihl handheld you can't go wrong
I also agree with the edger makes it look much better
