Trimmer will start but not run. If you put a spark tester in the circuit from the coil wire to the spark plug the trimmer runs perfect. It works with a spark tester light or a gap jumper tester. I have seen this work on this trimmer several times. I have worked on these things for over 5 years and never seen this before. Would appreciate any explanation for this and a solution for the problem. Thanks. Bill
