More CCAs for my 25hp Kawi
hayboy
Anyone got a battery with more cca than Tractor Supply with 360, the one I have is 2 yrs old and motor is bad slow, yes the valves are adjusted, might need a new starter. Mower has 520 hrs. If every thing is good to go, what should voltage at starter be while cranking with a good battery, (mine is 11 give or take .1) is there a normal "loss" between bat ( mine is 12.6) and starter? Just asking THANKS
11 V while the starter is cranking is good 10V is acceptable .
Clean up all the contacts and don't forget the earths
Check the starter gear for wear.
If the bottom of the starter get too hot to hold you might need to have a look at the starter brushes & contacts.
