- Nov 29, 2014
- Threads
- 64
- 24,647
Hey everyone, sorry it's been a while since any updates. After finally getting to mess with the mower I discovered that the belt did slip off the pulley. It got wedged under the pulley and was apparently keeping it from moving at all, even with the engine running. When I was able to pry it free and get it back where it goes, the mower magically moves again! New question... It feels like I've lost a bit of power. Could being bound up so bad have caused issues with the engine, or would it make sense that the belt was stretched/heated enough that I'm not getting full power? I ordered new belts and a full tune up kit for it and will do those as soon as I can, just wanted input. Also it feels like my controls have more slack in them than they did and it moves more than it previously did when I go from park to neutral. May be unrelated but if there's any way to adjust that I'd like to go ahead and try.
Thanks everyone! This is ending up to be a far cheaper fix than I was afraid it would be and I can't wait to tackle the jungle that has grown while I've been mower less!
You will most likley find the belt has been damaged where the engine pulley was spinning against it.
So a new belt might be in order and it is not going to be a fun job
