beg
- Aug 7, 2013
- Threads
- 48
- 239
I am not one to give up but this one has me baffled and could possibly be cursed .The first thing I noticed wrong was the primer bulb was leaking so it was replaced not an easy find as it is a wet primer bulb.The starter rope broke on the second pull so I fixed that and it starts but will not rev up I pulled the jets and sprayed carb cleaner in the holes and set the jets to factory spec but still it will only run at a low rpm and will die after 10 to 15 seconds.Motor has good compression Would like someones opinion as to what is wrong.
