Results 1 to 9 of 9
  1. #1
    Join Date
    May 2011
    Posts
    4
    Location
    Maine
    Mower
    Ariens
    Replacing Mandrel Housing on Ariens Riding Mower
    One of my mandrel housing's has broken off the deck of my Ariens: A175BG42, 936046. I have found the replacement part, (part # 187281). BUT, my question is: how do I get the mandrel spindle shaft assembly out of the broken housing? I'm assuming I can still use this spindle assembly with the new housing? Attached pictures are of the broken housing with shaft still in place. And yes, it was a GIANT rock, and it did have legs causing it to appear suddenly.
    Thanks for any help with this!
    Attached Images Attached Images
  2.
  3. #2
    1,000 Post Club
    RobertBrown's Avatar
    Join Date
    Aug 2010
    Posts
    1,278
    Location
    Florida
    Mower
    Ford
    Re: Replacing Mandrel Housing on Ariens Riding Mower
    Looks like you could pull it out. Did the new casting come with the bearing?
  4. #3
    Join Date
    May 2011
    Posts
    4
    Location
    Maine
    Mower
    Ariens
    Just ordered the new part. It won't come with a new bearing.
  5. #4
    1,000 Post Club
    Join Date
    Aug 2010
    Posts
    1,278
    Location
    Florida
    Mower
    Ford
    Quote Originally Posted by Jenkies View Post
    Post a picture of the new part or parts that were ordered and shipped.
  6. #5
    Join Date
    May 2011
    Posts
    4
    Location
    Maine
    Mower
    Ariens
    Here is the new part ordered!
    -Traci
  7. #6
    1,000 Post Club
    Join Date
    Aug 2010
    Posts
    1,278
    Location
    Florida
    Mower
    Ford
    It looks to me that the spindle should be tapped out from the pulley end, or tapped up from its operational postion.
    The spindle will move through the bearing near the pulley and will exit the housing with the top bearing in tow. Get it?
    You will need to secure the old housing and tap on the the threade end of the spindle, of course place a nut on the spindle and tap with a hammer
    The only other scenario is if the spindle is in two pieces, the joint being in the housing between the 2 bearings... not likely.
    Typically the whole spindle, bearing, housing assembly is replaced, but typically the assembly is shorter and more robust than what you have.
    Remember you can take both pieces to a machine shop and ask them to repair it. As they will have a press, I'm assuming you don't have a press.
    I have no direct experience with this particular assembly
    Oh yea after you get the spindle and top bearing out. Tap out the bottom bearing from the top with a drift then reassemble in the reverse on the new housing.
  8. #7
    Join Date
    May 2010
    Posts
    151
    Location
    Monmouth
    Mower
    I have done lots of these. Pretty straight forward, all parts can be tapped or drifted out of the old housing. A plastic mallet is the best thing to use.
    JMAC Small Engine Repair, Monmouth Illinois
  9. #8
    Join Date
    May 2011
    Posts
    4
    Location
    Maine
    Mower
    Ariens
    Thanks, everyone, for the advice! Looks like I'll be able to do this job with all the help you have provided. I'll keep you updated on my progress! The part is going to take a few days to get here.
    -Traci
  10. #9
    Join Date
    May 2012
    Posts
    43
    Location
    New Jersey
    Mower
    Husqvarna
    DOnt know if you have done the repair yet but here is my advice after doing a ton on my huskey. After you take the pully off take off the small washer that was under it, if you loose it you got to order another one and the pully will bind up when putting it on. Looks like you have gotten it out ok. NExt step, put the nut that held the pully on the shaft. make sure it is flush with the shaft and smack it out with a hammer. New one shold come with the lower bering but not the upper. Use a drift pin or punch and tap it from the inside of the mandrel housing to get it out paying close attention to strike on the edges of the bearing. Ps. Sorry for the horrible spelling
Similar Threads
  1. Riding Mower
    By ModernMode in forum Honda Forum
    Last Post: 06-23-2011, 12:54 PM
  2. Buying Advice Help Need Riding Mower
    By faithfullyforgive in forum Mower & Equipment Operation
    Last Post: 05-31-2011, 08:34 PM
  3. newbie w/a sheared mandrel housing
    By jinxed66 in forum Small Engine & Mower Repair
    Last Post: 05-16-2011, 02:45 PM
  4. Replacing blades.
    By Thunder in forum Small Engine & Mower Repair
    Last Post: 08-30-2010, 08:24 PM
  5. Need a riding mower!
    By dria in forum Mower & Equipment Buying & Pricing
    Last Post: 07-26-2010, 08:01 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
