Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
  1. #1
    Mark Widmer's Avatar
    Join Date
    May 2011
    Posts
    Location
    New Jersey
    Mower
    Black & Decker CMM1000
    Cordless electric enthusiast, new to forum.
    Just joined your fine forum, looks like us electric mower users are definitely in the minority here
    I've been using a Black and Decker CMM1000 cordless electric that my wife and I bought 5 years ago. The nearest service centers are over an hour away, so I have had to learn on my own to fix a few problems with it and other electric mowers that belong to friends.
    Looking forward to posting, learning, and helping out where I can.
    Mark
  2.
  3. #2
    1,000 Post Club
    twall's Avatar
    Join Date
    Feb 2011
    Posts
    1,628
    Location
    New York
    Mower
    Snapper SR1433
    Re: Cordless electric enthusiast, new to forum.
    Welcome to LMF, Mark!
    That thing looks simmilar to a Neuton......how close are they?
  4. #3
    Join Date
    May 2011
    Posts
    Location
    New Jersey
    Mower
    Thanks for the welcome twall!
    Looks like mine is comparable to the Neuton CE6: 19" blade, rear-mounted bag, and rated for mowing 1/3 acre**. But my CMM1000 runs on 24 volts while the CE6 used 36 V. Also, the CE6 battery is easily removable (unlike mine), easy to swap in a 2nd battery for cutting larger lawns ... a newer Black and Decker model has the swappable battery as well.
    **These manufacturers' acreage ratings must be under pretty ideal conditions. In practice I can't finish my yard on a single charge, and we have a 1/4 acre, not all of which is grass. Needs a 2 hour recharge halfway through mowing in order to finish up.
  5. #4
    1,000 Post Club
    twall's Avatar
    Join Date
    Feb 2011
    Posts
    1,628
    Location
    New York
    Mower
    Snapper SR1433
    I was intrigued by the neutron (I get Hanyman magazine, and see the ads all the time) for about an hour.
    Then, I found my Snapper - and the rest is history....
    How's that bag for capacity? How many times do you have to empty it in a 1/4 acre? My JD bagger is pathetic - 4 dumps per mow - and I'd say it's about a quarter.......
  6. #5
    Join Date
    May 2010
    Posts
    557
    Location
    Minnesota
    Mower
    country clipper (jazee)
    Mark widmer
    I'm not real impressed with black and decker string trimmer that are cordless i have the grass-hog 18 volt. Those batterys don't last long enuff to trim around 3 building and three trees , it takes two batterys to trim that little bit.Any one have any idea to make those battery's hold a charge longer?
  7. #6
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Quote Originally Posted by Mark Widmer View Post
    Mark
    Welcome to the forum Mark....
    I am no longer a user ... but I am a past user & still a proponent of electric mowers ... I had a great pair of John Deere Electric 90's... wonderful electric rider mowers... good to see you here using electricity... KennyV
  8. #7
    1,000 Post Club
    jmurray01's Avatar
    Join Date
    Apr 2011
    Posts
    1,490
    Location
    Scotland
    Mower
    Sterling Cyclone with Tecumseh Vantage 35
    Who needs electric when you have petroleum power!
    Seriously though, I have a Flymo/Electrolux Micro 330, and a Qualcast Mow 'N' Trim. Both electric, and I use them both from time to time.
    Live every day as if it's your last - because one day - it will be.
  9. #8
    Join Date
    May 2011
    Posts
    Location
    New Jersey
    Mower
    Hey, thanks for the additional welcomes, everybody
    Quote Originally Posted by twall View Post
    Yeah, it doesn't hold much. But not a big deal for me, I usually go with mulching mode anyway. Except once in a while when I want some cut grass to "feed" my compost pile. The bag is nice for cutting up and compacting leaves in the fall too, but it sure fills up fast like you said.
    Quote Originally Posted by noma View Post
    Mark widmer
    The B&D cordless Grass Hog uses a NiCad battery. Better to get something with a lithium battery. Those batteries last longer, and it's my impression that manufacturers tend to make better chargers for their lithium tools than for ones that use NiCads, in terms of not overcharging the battery.
    I'm pretty happy with my Worx cordless trimmer (model GT WG151.5), I can go 20 or 30 minutes on 1 charge. If I had it to do over I would get the slow-charge version instead of the fast 30-minute charger. I wonder (can't confirm it) if the fast charger might have ruined the original battery, which they replaced for free to their credit. Don't know if this is an exception to my "lithium chargers are made better" theory, it could have just been a defective battery too.
    Quote Originally Posted by jmurray01 View Post
    Seriously though, I have a Flymo/Electrolux Compact 3000+, and a Qualcast Mow 'N' Trim. Both electric, and I use them both from time to time.
    Hard to argue against having power. The less powerful electrics seem more sensitive to dull blades and wet or tall grass, you just have to be willing to accept the limits along with the advantages ... and learn to sharpen your own blades! (Or maybe I should be more careful around all the stones that line our yard )
    Mark
  10. #9
    1,000 Post Club
    twall's Avatar
    Join Date
    Feb 2011
    Posts
    1,628
    Location
    New York
    Mower
    Snapper SR1433
    Quote Originally Posted by KennyV View Post
    I looked those up - they look a lot like my RX75! Too bad they are so rare. I've never seen one, and had you not mentioned it, would've never known they existed.....
  11. #10
    Join Date
    May 2010
    Posts
    5,447
    Location
    Mower
    CTL
    [QUOTE=twall;23434
    ... they look a lot like my RX75! ....[/QUOTE]
    I believe everything except the engine compartment is the same...
    Too bad you are farrrr away ... I would give you them, I'm sure most pf the parts are the same as the gas version...
    The Electric 90 uses a 36 volt constant speed motor that belt drives a 3 speed & reverse standard gear box transaxle, rear drive wheels are a 5 bolt hole but bolt to a 3 bolt hub. Clutch and brake peddles look the same, Steering wheel is a 3 spoke wheel.... KennyV
Similar Threads
  1. Corded or cordless?
    By TedBeal in forum Mower & Equipment Operation
    Last Post: 08-16-2011, 08:21 PM
  2. Electric ZTR there IS one...
    By KennyV in forum Mower & Equipment Buying & Pricing
    Last Post: 06-08-2011, 03:41 PM
  3. Machinery Enthusiast New To Forum
    By Roybretton in forum New Members
    Last Post: 05-02-2011, 11:25 AM
  4. Bolens enthusiast new to site
    By Bigdaddydon in forum Bolens Forum
    Last Post: 04-03-2011, 10:30 PM
  5. electric clutch
    By coryc in forum Small Engine & Mower Repair
    Last Post: 08-22-2010, 10:05 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
