2 stage mid-grade blower recomendations
tigercat
On the machine on the left , are those two brackets ( ? ) in front of the handlebar housing for a snow cab ?
Also , how did you mount your lights ? I doubt the one on my platinum housing isn't going to work well when I put a cab on it.
Hi Phil
Yes I put a snow cab on the bigger 30" machine. It's the platinum 30" with a 12 HP Briggs engine. The snow cab will be used for the first time this year, when I get the cold January blown snow, then I will try it out. The cab was a bit of a pain in the neck as I needed to weld the brackets (of the snow cab) to reinforce it so it won't drop on my head as I was testing it out. I think it will work well now, and it pulls off with a simple wing nut on each side.
The brackets on the machine are drift cutters. I used them last year so I ordered weights and the drift cutters for the 28" machine yesterday. The weights fit under the shovel and they weigh 10 LBS. It bolts on by pre existing holes stamped into the blower housing. It helps hold the machine down so the packed snow won't push up the machine as I travel around the walks.
The 28" machine is my spare machine if something happens, I won't be SOL. I have way too much walks to tend and I rather have a spare and service the machine the next day if something breaks down. So far knock on wood, the Ariens 30" machine is a tank with no issues yet.
The Ariens built in light I hate. As I walk around blowing snow, the light shines right into my eyes. (I'm 6' tall) So I went to Northern Hydraulics website and ordered lights for 20 bucks a piece and wired them up, with it own switches (one switch per light). I removed the existing light and sanded the plastic lens down, then painted it black. I mounted the "new" lights around the dash so it fits nice. The new lights throw light like the old tractors of years ago. Awesome improvement!
No worries on the electrical system as the new Polar Force engines put out enough electrical power, so even with both lights and hand warmers on the lights still shine brightly.
I added my own "roller shoes" on these machines to help out on wear from the cement sidewalks destroying the standard skids on the snowblowers. Now the bearings simply roll down my walks. The skid plate don't need to be adjusted any longer so the snow is always scraped just right down the walks...
Here are the pics.
On youtube I made a short movie how the roller shoes work.
http://youtu.be/VG1giQ0heaY
1894
Thanks Tigercat . Did you put the snow cab together yourself or have the dealer do it ? The reason I ask is that I ordered a cab when I ordered the blower ( Ariens plat sho 24" ) . The machine was ready for delivery when I wanted it here . I was heading to camp for a few weeks and wanted the machine here just in case , and if that wind was just a little more Southerly we would have gotten snow along the lines of what buffalo ny got while I was away so I had it delivered. Cab was out of stock and the dealer really wanted for them to put it together and instal it before delivery. So I wonder if I should pay the 25 $ for pick up and instal the cab or try it myself ? If it would take me ( not very mechanically inclined ) much over an hour to go from package to installed I may try and see if I can get them to do it .
Your , or anyone else s thoughts on the cab set up and instal ?
Re the new lights , did you just use the wires from the dashboard light and extend them to the switch (s) and lights or a new set of wire from wherever the power feed comes out from the motor ?
tigercat
There is a movie on you tube of a guy with his Ariens cab as he put it together. I will try and find it and edit my post. The cab went together in about an hour. Becaue of my add on lights, I had a harder time with the brackets and the final locations. You put the brackets on the machine first, then you assemble the snow cab, but leave the final brackets loose so you can fit them into the frame. It just goes together like pressing pipe ends into each end.
My problem with the snow cab was if you look at the inner view of my picture you will see where I welded the thing together. At that point it would slip and the top of the cab would drop on my head as I would bump the machine around testing it out.
Well I drilled a hole thru the bracket and inserted a 1/8 inch screw into the collar that was slipping. Then I welded it up to add insurace it won't fall apart as I'm using it. I think it's solid now, but I haven't used it yet. You can see where it's welded on the picture.
For 25 bucks they could put it together (but that's just my lazy side talking). The cab is big when put on the machune. Transport could be tricky with the cab on the machine.
Oh yes on the lights. I extended the orginal wiring and switched the lights and added the lights. The lights are the single best thing I done for the machine. Winter time, you clear snow in the dark and now with house spot light on or not, I can see easily where I'm going. I also can see where my tires are as I walk down the walks too!
First movie is the man I seen before I put mine together
The next movie is more brief.
http://youtu.be/PK6Vni3V0sA
http://youtu.be/_cIgfnRPBmc
1894
Thanks again ! I saw the first video before and that was what made me worry a bit after watching him struggle . I think I got more info about his phone than the cab in that hour long video :laughing:
The second one helped a lot more , thanks for finding that one.
In the first video the guy talked about needing spacers to keep the nuts far enough onto the threads of the bracket bolts. Did you find you needed anything like that ?
And thanks for the info on the lights as well :cool:
tigercat
The studs are long so I just used a metric ton of flat washers under the nuts. Otherwise your screwing the nuts all day long and you will run out of threads before it tightens up.
See my pictures, you can see on the frame (bottom side of cab) the brackets are 'full" looking... Full of washers. :laughing:
1894
Got to use the machine the last few days :cool:
Glad I went with the 24" with the 306 motor. I needed the extra power to do what I need done. I've cut banks back along both sides of our 150' section of road that the plow truck left after 18"+ of heavy snow , did a bunch of just regular snow , cut back some corners where the plow left bigger piles , and just spent time learning the machine and snowblowing. We'll see how it handles the season , so far so good :thumbsup:
You can keep track of our snowfall here in syracuse ny by checking these two pages :
GoldenSnowball.com | The Golden Snowball Award is a contest between 5 cities in CNY – Upstate New York. The contest is based on which city receives the most snowfall for the snow season. The cities that compete are Albany, Buffalo, Binghamton, R
Golden Snow Globe National Snow Contest Snowiest US City Pop 100,000+ | A fun national snow contest for the snowiest city in the United States with a population of 100,000 or more! Check to see if Your city winter snowfall totals are listed.
gfp55
It's good to hear you found a blower that you like. Maybe you post pictures of your blower at work?
1894
Will do gfp55 .
1894
No pics yet , been a very light snow season so far . :cool:
reynoldston
I live just east of Rochester and its been a very lite year for snow so far. That can change over night. I do get different brand snow blowers in my shop for repairs. I have found that Ariens seems to be the most popular brand snow blower in this area of the state. I have found the biggest repair I have made on them is just a very simple drive linkage adjustment. On some of the older models I have replaced axle bushings. Other then that they are a very easy machine to work on and the front blower attachment removes very easy. You wouldn't be sorry you went with Ariens and if taken care of should last you for many years of service. I have found for myself that when operating the Ariens snow blower they are much easier to handle in one drive mode then the two wheel drive mode. This is something you will have to try yourself to see what you prefer.
