Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Apr 2011
    Posts
    11
    Location
    Keswick
    Mower
    Mower blade replacement
    Where is the best/economical place to purchase new mower blades for a Kubota ZD25 60" deck?
  2.
  3. #2
    1,000 Post Club
    twall's Avatar
    Join Date
    Feb 2011
    Posts
    1,628
    Location
    New York
    Mower
    Snapper SR1433
    Re: Mower blade replacement
    Quote Originally Posted by MarineScott View Post
    WELCOME TO LMF!!
    Have you tried Home Depot or Tractor Supply?
  4. #3
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Bailey's has Oregon blades see at this site...
    http://www.baileysonline.com/itemdet...m=OEP%20491438
    Mow More has these...
    Kubota Lawn Mower Blades: 60 inch deck
    There are a few other places, with good replacement blades... KennyV
  5. #4
    1,000 Post Club
    Briana's Avatar
    Join Date
    Jul 2010
    Posts
    1,550
    Location
    California
    Mower
    Looking to Buy :)
    Hello, I have moved your post to the Kubota Forum. You will have better luck finding assistance there.
    Thanks for joining LawnMowerForum!!!
  6. #5
    Join Date
    Mar 2011
    Posts
    35
    Location
    Maryland
    Mower
    Kubota
    I've been thinking about installing mulching blades on a 60" deck without a mulching kit. How are the mulching blades when it comes to grass collecting under the deck? Thick, wet grass seems to collect under the deck and impedes grass discharge with the standard blades. Do mulchers cut the grass into finer pieces and only increase the problem?
  7. #6
    1,000 Post Club
    BKBrown's Avatar
    Join Date
    May 2010
    Posts
    1,415
    Location
    Virginia
    Mower
    VENTRAC
    I know Kenny did not have good luck with these, but I like them.
    They cut the grass clippings finer and throw them farther out the chute + the blades (knives) flip back if you hit anything. If you are interested, just look up Meg-Mo !
  8. #7
    CajunCub's Avatar
    Join Date
    Mar 2011
    Posts
    182
    Location
    Louisiana
    Mower
    LTX1046 Hydro
    I have used these guys: onlymowerblades.com
  9. #8
    Sprinkler Buddy's Avatar
    Join Date
    Apr 2011
    Posts
    289
    Location
    Florida
    Mower
    60" 30 HP Hustler's
    Several online retailers, take your pick. Look for one with free shipping. If your only wanting one set, a local retailer will have after market blades from rotary, etc... You may not be able to get free shipping with an order of only 3 blades.
  10. #9
    Join Date
    Apr 2011
    Posts
    289
    Location
    Florida
    Mower
    60" 30 HP Hustler's
    Quote Originally Posted by slc10844 View Post
    I tried mulching blades in the past. They tend to bend easy if you should accidently hit a root or anything hard. I have gone to a low lift blade now for several years. My deck loves them!! They don't suck up all that sand in dryer conditions like the others, including mulching blades. They cut just as well if not better in my opinion. Anyone reading this, they do make after market low lift blades for most all makes and models. One can also cut wet grass with not nearly as many clumps. I try not to cut wet but sometimes you don't have a choice. Get-ER-Done!
  11. #10
    Join Date
    May 2010
    Posts
    5,447
    Location
    Mower
    CTL
    I think build up is mostly a deck design problem... a bad design will most likely have more trouble with some blades than others... But I have switched to mulching blades with no change... I've never had any build up problem...
    Oregon Gator mulching blades.... OREGON brand Lawn Mower Blades
    They work great... KennyV
Similar Threads
  1. Using a balancer on a mower blade
    By mois25 in forum Mower & Equipment Operation
    Last Post: 09-30-2016, 08:52 AM
  2. Cub Cadet mower blade nuts
    By jross in forum Small Engine & Mower Repair
    Last Post: 04-23-2011, 04:35 AM
  3. Paddle/Blade Replacement
    By dcgrazier in forum Snow Removal
    Last Post: 01-13-2011, 05:45 PM
  4. mower blade pick
    By dvantuyl in forum Mower & Equipment Operation
    Last Post: 10-09-2010, 12:42 AM
  5. Soil conditions vs. mower blade life
    By Coolnorth in forum Small Engine & Mower Repair
    Last Post: 05-17-2010, 10:27 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
