Results 1 to 4 of 4
  1. #1
    Join Date
    Apr 2011
    Posts
    16
    Location
    Ohio
    Mower
    Cub Cadet LTX 1050VT
    B & S gas tank replacement
    Anyone on here own a pushmower with B&S engine, that has had the fuel tank split? I have done some internet searching and apparently it is a fairly common issue. I would have expected to see some kind of recall, with as much emphasis they are putting on environmental issues (i.e. no-leak fuel cans that we all love so much). Am I stuck just shelling out $35 for a new fuel tank?
    Mike
  2.
  3. #2
    Join Date
    May 2010
    Posts
    151
    Location
    Monmouth
    Mower
    Re: B & S gas tank replacement
    Briggs did have a recall on these, but it was several years ago. Before you pay for the new tank you miight be able to get your briggs dealer to call his area rep and possibly get a free tank. I say possibly because the recall may not have included your tank, but it is worth a try.
    JMAC Small Engine Repair, Monmouth Illinois
  4. #3
    1,000 Post Club
    RobertBrown's Avatar
    Join Date
    Aug 2010
    Posts
    1,278
    Location
    Florida
    Mower
    Ford
    That would be me. I bought another but it was about 20$ if I recall correctly. I bought mine about 6 years ago. Haven't had problems with the replacement. There is a picture of the mower in the ugliest mower contest.
  5. #4
    Join Date
    Apr 2011
    Posts
    16
    Location
    Ohio
    Mower
    With the grass growing so fast you can almost see it, I just bit the bullet and ordered a new one. Mower started on the second pull. And no more gas leaks!
Similar Threads
  1. leaking gas tank
    By glenn in forum Small Engine & Mower Repair
    Last Post: 04-28-2011, 05:36 PM
  2. Gas tank
    By monica123 in forum The Front Porch
    Last Post: 02-17-2011, 02:34 PM
  3. honda hs55 snowblower, gas tank removal??
    By bruca003 in forum Small Engine & Mower Repair
    Last Post: 11-25-2010, 10:38 PM
  4. Replies: 4
    Last Post: 08-03-2010, 08:07 PM
  5. Sand in the Gas Tank
    By BlueGrass in forum Small Engine & Mower Repair
    Last Post: 05-30-2010, 06:50 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
