Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Join Date
    May 2010
    Posts
    100
    Location
    New Jersey
    Mower
    John Deere 56
    Cub Cadet mower blade nuts
    I am now in the process of working on the deck the Cub Cadet 1600 that was given to me. I have been heating the blade nuts and squirting PB Blaster on them and still cannot get them loose. I am now considering just cutting them loose with a Moto-Tool. I do not want to beat them with a maul because I think the spindles are still ok. Any suggestions? The deck has been repaired by welding which I intend to grind off and patch with heavy sheet metal on both sides.
  2.
  3. #2
    173abn's Avatar
    Join Date
    May 2010
    Posts
    852
    Location
    JF county,Kansas
    Mower
    JD111,CF GT18,928d grasshopper
    Re: Cub Cadet mower blade nuts
    jross,keep soaking them with PBlaster and if you have an air impact wrench then you should have no problem getting them off...russ
  4. #3
    2,500 Post Club
    JDgreen's Avatar
    Join Date
    May 2010
    Posts
    2,887
    Location
    Michigan
    Mower
    Too many, running or not
    Quote Originally Posted by 173abn View Post
    When I was younger and couldn't afford an air impact wrench, I had pretty good success at breaking loose rusted fittings by using a SNUG fitting wrench and a section of pipe slipped over the wrench, or whacking the free end of the wrench with a section of 2X4. It also helps the penetrating oil soak into the threads if you tap on the head of the bolt or side of the nut with a plactic tip hammer, the vibration helps the oil soak in.
    "I didn't plan to do anything today, but by noon I was almost half done...."
  5. #4
    1,000 Post Club
    BKBrown's Avatar
    Join Date
    May 2010
    Posts
    1,415
    Location
    Virginia
    Mower
    VENTRAC
    Does anyone know if they happen to be left handed threads ?
  6. #5
    Join Date
    May 2010
    Posts
    100
    Location
    New Jersey
    Mower
    John Deere 56
    Quote Originally Posted by BKBrown View Post
    Looking down at the blades, they rotate in a counter clockwise direction, indicating they are right hand threads.
  7. #6
    173abn's Avatar
    Join Date
    May 2010
    Posts
    852
    Location
    JF county,Kansas
    Mower
    if you don't have an air impact wrench then agreed a "helper " is your best bet.try using a box end wrench and liberal amts. of the blaster. russ
  8. #7
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    I don't think Cub Cadet ever did that ... there are some others that have...
    Impact wrench will get it like russ suggests ..KennyV
  9. #8
    Jetblast's Avatar
    Join Date
    Mar 2011
    Posts
    271
    Location
    Ohio
    Mower
    Cub Cadet Commercial Pro Z 560 S
    It was that same job that caused me to go down to Harbor Freight and get a Chicago 1/2" electric impact wrench ten years ago. The blade nuts came right off and I've been using it ever since for this, and for rotating tires on various vehicles. If you don't have an air compressor it's a good and cheap way to get the job done. Lots of good reviews on that product, it's one of their better items.
    Definitely a standard thread on those. Counter-clockwise to remove.
    BTW I got the first blade nut off by jamming a wood scrap between the blade and the deck to prevent rotation, then I hit the handle of a huge Crescent wrench with a rubber mallet. It cost nothing and it worked, but I didn't see myself doing that forever so I sprang for the HF wrench.
  10. #9
    poncho62's Avatar
    Join Date
    Mar 2011
    Posts
    71
    Location
    Ontario, Canada
    Mower
    Fords, MF, JD, National
    Impact gun is the best way.....If you dont want to buy one, just take it to a local garage to get them off.....Then from now on, make sure they are taken off every year to keep them undoable...(is that a word?)
  11. #10
    Join Date
    Mar 2011
    Posts
    11
    Location
    New York
    Mower
    several makes
    Good advice above with impact wrench, I put never-seize on threads and also where the washer on the nut contacts the blade. That will help you the next time. Also I wouldn't put the nuts on with the impact.
Similar Threads
  1. Cub Cadet?
    By Ken Fountain in forum Cub Cadet Forum
    Last Post: 04-30-2011, 06:15 AM
  2. Repairs cub cadet 173cc push mower problems
    By wagonburner in forum Cub Cadet Forum
    Last Post: 03-29-2011, 11:22 AM
  3. Replies: 1
    Last Post: 01-16-2011, 12:31 AM
  4. Snow Blade for a 1610 Cub
    By Old Grunt in forum Cub Cadet Forum
    Last Post: 01-06-2011, 10:32 PM
  5. Cub Cadet Decks
    By junior beasley in forum Cub Cadet Forum
    Last Post: 09-01-2010, 12:01 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
