Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    Join Date
    May 2010
    Posts
    Location
    Blount County
    Mower
    Oil filter for Kohler Cub
    I bought a new Cub last year with the Kohler engine and the filter was a little over $11, and I noted that it looked exactly like the one I use on my 03 Camry, a Fram DG-3614.
    I even put the Fram on the Kohler and it fit perfectly, but I didn't leave it on, I put the "OEM" filter back on.
    I know you only buy the filter once a year, and the difference between $4 and $11 isn't all that much, and I wouldn't worry about it if I thought that I would damage the engine, but I hate to be "had" by the parts people . . .
    Does anyone have any knowledge/thoughts on this issue ? ?
  2.
  3. #2
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Re: Oil filter for Kohler Cub
    winwun
    Welcome to the forum...
    You have came across a problem in distribution...
    There are many times more automotive filters made and sold than small engine filters.. with quantity comes economy.
    If you look up the specs on those two filters you will find all the relevant issues to be the same... NOT similar but exactly the same.
    The same: Full Flow Media: Paper Height: 3.404 Outer Diameter Top: 2.921 Outer Diameter Bottom: Closed Thread Size: 3/4-16 By-Pass Valve Setting-PSI: 8-11 Anti-Drain Back Valve: Max Flow Rate: 7-9 GPM Nominal Micron Rating: 21
    The SAME gasket... O.D. I.D. and Thickness...
    The automotive filter is the correct one for applications that range from the Yugo to the Lexus PLUS Various Lawn&Garden, Farm & HD Equipment ...
    So... guess what one is the best for your application... Remember... the important components are identical... KennyV
  4. #3
    jd335's Avatar
    Join Date
    Jun 2010
    Posts
    135
    Location
    Virginia
    Mower
    welcome to the forum winwun i have the same filter on my toyota 4 runner that fits my jd mower the thing i can add is in my 20 plus years working on autos i have seen several fram filters colasp and cause major damage i never use them i know they advertize them alot but that don't make them good. we have used wix filters and never had any problm with them.
  5. #4
    Join Date
    May 2010
    Posts
    5,447
    Location
    Mower
    CTL
    Quote Originally Posted by jd335 View Post
    ...we have used wix filters and never had any problm with them.
    I'm with you on WIX...
    only problem ever seen on any Wix was for a short time they didn't have completed threads...
    Aside from that short lived problem, I think they are toward the TOP of filters... My FIRST choice... KennyV
  6. #5
    Jetblast's Avatar
    Join Date
    Mar 2011
    Posts
    271
    Location
    Ohio
    Mower
    Cub Cadet Commercial Pro Z 560 S
    I had a similar euraka moment the first time I had to put a new filter on my old tractor's Kohler Command. Looked awfully familiar, so I compared it to the Purolator PureONE filters I'd been using on my Toyota 4Runner and it was a bingo. Been using them since.
    Always best to avoid Fram like the plague. If you Google around you'll find some comparisons where guys have cut apart different brand filters, and the Frams always look bad. They use cardboard endcaps glued on to the filter elements and other shortcuts, which lead to internal leaking.
    Edit: I may have been too hasty condemning Fram. Seems there have been key improvements since the old data made the rounds. This thread features a fairly convincing response to them from a Fram representative.
  7. #6
    Join Date
    May 2010
    Posts
    5,447
    Location
    Mower
    CTL
    I think Fram got so bad... AND it became very common information as to how bad they had became... that they HAD to make things better...
    I still stick with Wix ...
    Fram has got to be better than they were...
    But in fairness to all filters, any filter is better than no filter and air cooled small engines were around for decades with no filter at all, same with car engines, prior to the fifties automobile engines did not normally come with filters... KennyV
  8. #7
    Join Date
    Mar 2011
    Posts
    11
    Location
    Ohio
    Mower
    Dixon
    I've a Kohler Command engine on my Dixon, now 17 years old. I think the first 4-5 years I used the Kohler filter, then found a cross reference to Wix, Purolator (and Pure one) and Mobil 1 filters. Several of these are cosidered premium filters...and in my opinion, much better than Fram, and probably better than the Kohler. So, in the 12 years or so since I got the cross reference, I've used the others. I just replaced that mower with a larger one, another Kohler engine....and I intend to do the same. Now if I could just cross the Dixon hydraulic filter to a common brand, I'd be set.
  9. #8
    Join Date
    Jun 2011
    Posts
    Location
    kingwood
    Mower
    i crossed both filters on my cadet to napa filtersit has a kohler motor was using original filters until i crossed them now use napa filters they are the same as wix filters.
  10. #9
    Join Date
    Oct 2010
    Posts
    503
    Location
    Kentucky
    Mower
    1993 John Deere F725, 2000 John Deere 335, 2010 John Deere 3038E
    Quote Originally Posted by Jetblast View Post
    How long ago was this last data released? I have a buddy that works in the paper industry, his factory produces paper for oil filters. I'm not going to give any names or locations for obvious reasons, but he and the factory are not located in Western Kentucky, Southern Illinois, Southeast Missouri or Western Tennessee.
    As part of their quality control process, they routinely purchase filters for which they produce the filter paper. They just go to the parts stores in their area and buy them off the shelf. Amongst other tests, they check for intial pass efficiency and multiple pass efficiency. He told me in 2004 or 2005 that the Frams do very well on the initial pass, but fail miserably on multiple passes. The paper Fram used, at least at that time, was the cheapest this factory made. An off brand filter sold at a huge box store retailer tested far better. I don't use Fram anymore.
  11. #10
    poncho62's Avatar
    Join Date
    Mar 2011
    Posts
    71
    Location
    Ontario, Canada
    Mower
    Fords, MF, JD, National
    NAPA filters are made by Wix....so I have been told
Similar Threads
  1. Replies: 12
    Last Post: 01-02-2013, 08:45 PM
  2. 30W oil
    By JDgreen in forum Small Engine & Mower Repair
    Last Post: 04-14-2012, 09:43 AM
  3. Murray Push Mower Air Filter Assembly and Tires
    By carl22 in forum Murray Forum
    Last Post: 08-19-2011, 07:32 PM
  4. DIY Oil changes or have it done?
    Last Post: 12-31-2010, 02:31 PM
  5. Hydraulic oil:
    By stoneyrunmiller in forum Small Engine & Mower Repair
    Last Post: 10-01-2010, 09:55 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
