Hustler FasTrak 44 EZT drives
budlin35
I have this mower and after cranking and running it for a while, one of the drive pumps heats up and stops pulling. Any one of you ever experienced this and is there an easy repair?
clpolcar
I am pretty sure there is air in the system. Jake the rear end up. And crack the valves and bleed the system. Go forward and reverse with the rear end in the air
