I have a john deere 165. I need to replace a steering column bushing but can not get the steering wheel off. I found the sectional diagram for this model on line and it appears the only thing holding the steering wheel on is a splined bolt. I have removed the splined bolt, sprayed rust remover everywhere possible and used jaw pullers but can't budge it. I created a steel plate to fit under the steering wheel that I could attach the jaw puller to for a more even pull but still had no luck. I am looking for suggestions???
Thanks, John
Thanks, John
