John Deere RX 95
Butch1957
I was given this old tractor by my grandfather and I have a dilemma: It has a 12.5 Kawasaki electric start engine. Very sound running engine and worth keeping but when it is running and I engage the shifter for forward or reverse the engine will die. There is no safety switch under the seat. I pigged tailed the wires that run to the Trans Neutral Safety Switch that is located on top of the transmission and when I do so the tractor works fine in either gear. So I replaced the Trans Neutral Safety Switch with a new one and it does the same thing. But when I pig tail the wires leading to the switch it works fine.
Does anybody have a suggestion ?
Please Respond.
Thanks.
BBO
II replaced the Trans Neutral Safety Switch with a new one and it does the same thing. But when I pig tail the wires leading to the switch it works fine. Does anybody have a suggestion ?
I suppose this switch works from the brake. So you could check all the linkage to the brake to see if it has the brake on.
I am not familiar with the RX95 but most mowers will simply not start unless the brake is set on.
Are you sure it will move & mow fine and normal with the jumper on?
Will it start without the jumper on?
Strange details...
chiefridd4
Please Respond.
Thanks.
Did exactly same and got running. Thanks for the info.
