OTWLAWNMOWERMAN
- May 11, 2013
- Threads
- 3
- 11
I have a problem with my Troybilt push mower. It has had inter. starting problems. I checked for spark "none." I pulled the kill wire off, then I had it. The wire was good so I looked at the brake to the flywheel, and the wire was attached. I don't know in what orientation the wire should go on the brake. I took it out of the clip and I also had spark. does anyone know or have pictures of the correct place for it? It's a briggs professional 7.75 11p902-0693-b1 09110562. I can add pics if needed.
Thanks.
Thanks.
