Results 1 to 6 of 6
Thread: Bent/broken flywheel key?
01-16-2011, 04:38 PM #1
I have an '01 vintage Craftsman 6.75 hp self propelled, tried to start it two years ago and the starter rope broke, since I hade newer mowers I set it aside. Wanted to get it running this fall to bag leaves, after replacing the rope I tried to start it. It acted like the engine was trying to backfire, the rope would pull back IN toward the engine at times, it would push vapor out of the exhause but never even fired. Fuel is getting to plug, plug is working well....
It's a Briggs engine.
Did a Google search and found several references to the same model of mower, supposedly if you hit a rock of something the flywheel key will bend or break to save the engine from damage, and with the key damaged the timing will be off far enough the engine will not start and will kick back when pull starting.
What I find odd is, I did hit a rock hard enough a few years back that iot ruined the blade, but when I replaced the blade with a new one, the engine started right up and ran fine then. Wonder why the flywheel key problem would surface two years later?"I didn't plan to do anything today, but by noon I was almost half done...."
Advertisement
01-16-2011, 04:47 PM #2
Re: Bent/broken flywheel key?
That does seem odd that it worked fine after changing the blade. Nevertheless, the symptoms you have now do indicate the flywheel key is bent/sheared off. It's easy enough to check. Maybe when you're fixing it, the reason will present itself.
If you do find something, I'd be curious to know what it is.Erik G
01-16-2011, 07:03 PM #3
01-17-2011, 02:39 AM #4
- Join Date
- Jan 2011
- Posts
- 1
- Location
- Riverside
- Mower
- Too many
The problem is surely a broken flywheel key, what might of happened is when you hit something you sheared it in half but it might of still held the timing correct, over time though it is possible the timing got thrown off. It's an easy fix and if your careful you don't have to even use a flywheel puller or knocker. Just make sure that when you put the flywheel back on you gap the coil clearance to the flywheel with a business card.
01-17-2011, 05:01 AM #5
1,000 Post Club
- Join Date
- May 2010
- Posts
- 1,579
- Location
- Atlanta, GA/Cleburne County, AL
- Mower
- Lawn Boy, Toro, Jacobsen
I might add that flywheel keys are made from softer metal so that, if put under unusual stress, the key (a cheap part), will fail -- hopefully saving the flywheel and crankshaft (much more expensive parts.)
Robin: My name is Richard Grayson. The other kids call me Dick.
Batman: Well... children can be cruel.
from The LEGO Batman Movie
01-17-2011, 12:55 PM #6
I have busted and replaced mine at least 4 times. I now keep spare keys in the garage. Probably the same mower only mine says "MTD" on the side, same rated horsepower anyway.
Similar Threads
snapper snowblower repair advice (broken spring)
By noma in forum Snow RemovalReplies: 10Last Post: 12-27-2010, 04:58 PM -
Repairs Anyone know the size of rear axle key
By farmerdoc in forum John Deere ForumReplies: 2Last Post: 09-22-2010, 04:37 PM
