Results 1 to 5 of 5
  1. #1
    Join Date
    Aug 2013
    Posts
    Location
    canada
    Mower
    158cc 5.00 briggs n stratton
    not getting enough fuel to run properly
    I have a Yardman 158cc 5.00 briggs and Stratton. Would someone explain to me how to locate fuel filter.
  2.
  3. #2
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,601
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Re: not getting enough fuel to run properly
    Very good chance it doesn't have a fuel filter.
  4. #3
    Join Date
    Aug 2013
    Posts
    Location
    canada
    Mower
    Quote Originally Posted by reynoldston View Post
    The mower has only run about 15-20 hrs. Do you recommend that I do anything to carbeurator, maybe the butterfly valve sticking????
  5. #4
    Join Date
    May 2011
    Posts
    5,601
    Location
    Marion,NY
    Mower
    If you think you have bad fuel flow check it out first. If you don't have a shut off valve block off the fuel line as close to the fuel tank as you can ( clamp or vice grips). Remove fuel hose at carburetor and loosen your clamp with a container under the hose to catch the fuel. This will let you know if you have bad flow or not. I am taking a guess this is a push mower and has a fuel primer. Yes if you have been putting dirty gas into your mower you can well be having carburetor problems and need the carburetor cleaned.
  6. #5
    Join Date
    Aug 2013
    Posts
    Location
    canada
    Mower
    Thanks for the info, I will try after work and let you know tomorrow.
Similar Threads
  1. Learning to run a business properly
    By twoguyswithmowers in forum Commercial & Residential Lawn Mowing
    Last Post: 08-14-2013, 08:24 PM
  2. Valves not opening and closing properly
    By bluefitness in forum Small Engine & Mower Repair
    Last Post: 07-06-2013, 09:42 PM
  3. Husqvarna YTH20K46: Will not turn over properly!
    By Shooter56 in forum Husqvarna & Dixon Forum
    Last Post: 04-14-2013, 12:06 PM
  4. 6.5hp Briggs wont start properly
    By davbell22602 in forum Briggs & Stratton Forum
    Last Post: 05-15-2012, 05:27 PM
  5. Kohler CH20S Not operating properly
    By hukturn in forum Kohler Engine Forum
    Last Post: 05-20-2011, 05:39 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
