Results 1 to 2 of 2
  1. #1
    Join Date
    Jul 2013
    Posts
    Location
    Tennessee
    Mower
    Post Scag turf tiger wont start
    When I turn the key to start, nothing! I have checked the fuses, replaced the ignition module, checked the starter solenoid and relay, checked all switches including key switch except the seat switch. At first the mower would start at times but not always. Now it wont start at all. Mower is 2000 model 61 inch turf tiger.
  2.
  3. #2
    1,000 Post Club
    Join Date
    Jul 2011
    Posts
    1,774
    Location
    Connecticut
    Mower
    Scag Tiger Cub, Ingersoll 4018, Hustler X-ONE MoJack Pro
    Red face Re: Scag turf tiger wont start
    There is a start/cranking relay close to the key switch. When all the safety circuits are in line, then the module will ground the coil in the relay and allow cranking of the engine. The seat switch is one of the major players in the safety circuits, but actually all the switches play into the safety circuits including the PTO switch.
    If you do not have an operators manual which has the wiring diagram, you can download a manual from the Scag website, you will need the model and serial numbers from your machine to find the correct manual.
Similar Threads
  1. scag turf tiger
    By glomoore in forum Scag Forum
    Last Post: 05-31-2014, 07:32 AM
  2. Scag turf tiger will not try to start
    By jlkcfire in forum Small Engine & Mower Repair
    Last Post: 07-23-2013, 03:45 PM
  3. Scag Turf Tiger
    By Sdupus in forum Small Engine & Mower Repair
    Last Post: 06-14-2013, 04:52 PM
  4. Scag Turf Tiger
    By JCC in forum Small Engine & Mower Repair
    Last Post: 03-19-2013, 10:35 AM
  5. Scag Turf Tiger Kholer 25hp won't start
    By scag43 in forum Small Engine & Mower Repair
    Last Post: 10-05-2012, 01:05 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
