Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Limfe's Avatar
    Join Date
    Jul 2013
    Posts
    10
    Location
    New York
    Mower
    Engine backfires but won't start.
    I have a 1 1/2 year old craftsman with a 21hp briggs and stratton gold series plus engine. It turns over perfectly, I have plenty of spark and fuel. I believe the flywheel key is sheared. My concern withthe flywheel is the plastic cooling fins. Is there a specific way to remove them to get to the flywheel?
  2.
  3. #2
    Limfe's Avatar
    Join Date
    Jul 2013
    Posts
    10
    Location
    New York
    Mower
    Re: Engine backfires but won't start.
    Flywheel is off. Used an impact wrench to remove the bolt so I wouldn"t have to wedge the fins or flywheel with anything. The pin didn't shear. Instead it craccked the top of the flywheel shaft. Any ideas on what would cause that?
  4. #3
    Join Date
    Aug 2012
    Posts
    824
    Location
    California
    Mower
    TMW REPAIR & THE MUSICIANS WORKSHOP RECORDING STUDIO
    Quote Originally Posted by Limfe View Post
    Possibly when you removed the flywheel? How exactly did you remove the flywheel itself?
    After you removed the nut/bolt that holds the flywheel on, did the flywheel just lift off?
  5. #4
    Limfe's Avatar
    Join Date
    Jul 2013
    Posts
    10
    Location
    New York
    Mower
    I borrowed a flywheel puller but I didn't need to use it. The top of the flywheel was split so bad that I was able to lift the flywheel off with my hands.
  6. #5
    Rokon's Avatar
    Join Date
    Apr 2012
    Posts
    164
    Location
    Way down in Diddy Wah Diddy
    Mower
    ...is at my son's house :(
    Is there a chance that when "impacting" you may have tightened the flywheel more before breaking the nut loose?
  7. #6
    Join Date
    Aug 2012
    Posts
    824
    Location
    California
    Mower
    Perhaps someone used a steel flywheel key instead of the aluminum one?
  8. #7
    Join Date
    Jun 2011
    Posts
    565
    Location
    Knoxville, TN
    Mower
    Cub Cadet Zero Turn
    That took a really hard blow to split the flywheel or flywheel shaft (top of crankshaft?) like that. Could be over-tightening as aluminum won't stand up to it. Impact air gun would do it. I've seen tops of crankshafts mushroomed from hammering on them, even broken in two, but never split! On the other hand I've seen go cart racers tighten flywheels without the shear pin keys in them to advance time and they didn't crack them! Just have to get a lock washer to keep the wheel from turning. But in that case, if it did turn, what difference would it make since there is no flywheel key in it? Just re-set the timing position and try it again. I've never tried that but have friends who did.
  9. #8
    Limfe's Avatar
    Join Date
    Jul 2013
    Posts
    10
    Location
    New York
    Mower
    I called Sears and they sent out a service technician 2 weeks later. He ordered a new flywheel and key.. He said if if I waited for him to come back it would be over a week and said when the parts were delivered I could install them myself if I wanted. Seemed simple enough. Apparently when the flywheel split it may have caused internal gears to jump out of time. I removed the oil pan and realigned the marks on the cam and drive shaft gears. Engine still backfires and will not run. Someone had suggested the valve settings. After inspecting the valves I found that the exhaust valve seat was split in two and briggs waranty only covers replacement of the whole head assembly. That's fine and dandy but I would liuke to know if that broken valve seat could have set this whole fiasco into motion????
  10. #9
    2,500 Post Club
    Fish's Avatar
    Join Date
    Aug 2013
    Posts
    3,230
    Location
    Kentucky
    Mower
    I Don't Own a Mower :(
    Possibly so, but your messing with the engine so far would void any warranty.....
    As far as the cam/gears jumping out of time, I have to throw out the red "BULL" flag, and call the whole thread "bogus"?
    As far as removing the plastic fanwheel, that is obvious just by looking at it, why don't you post all of the engine's model, type, code numbers?
    Fish
  11. #10
    Limfe's Avatar
    Join Date
    Jul 2013
    Posts
    10
    Location
    New York
    Mower
    Quote Originally Posted by Fish View Post
    Fish
    The engine model number is 33187/0869 G5/111220ZA. The service tech stated to me that having me install the flywheel would not affect the warranty. Obviously the cooling fins were easily seen just by looking at it and I did not imply that any of the other issues had anything to do with it. The timing marks on the cam gear and the main gear were completely on opposite sides of each other. How or why this would happen, I have no idea. That would be why I asked on here.
Similar Threads
  1. John Deere LX176 backfires, won't start
    By LilJayV10 in forum Small Engine & Mower Repair
    Last Post: 08-06-2013, 05:45 AM
  2. Craftsman riding mower backfires, won't start
    By Laneman in forum Small Engine & Mower Repair
    Last Post: 06-03-2013, 09:14 PM
  3. backfires
    By fullgoosbozo in forum Small Engine & Mower Repair
    Last Post: 04-23-2013, 08:00 PM
  4. Briggs & Stratton intek 18 HP engine contunuously backfires
    By ajsm85 in forum Briggs & Stratton Forum
    Last Post: 04-10-2013, 06:54 AM
  5. John Deere 245 (14 hp Kawasaki engine) - backfires through muffler
    By junkman hobson in forum John Deere Forum
    Last Post: 03-27-2013, 02:21 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
