Results 1 to 2 of 2
  1. #1
    Join Date
    May 2013
    Posts
    Location
    Indiana
    Mower
    Ignition Switch???????
    was mowing with simplicity 16gth with biggs and stratton and turned key off and mower would not shut down, I choked it out and now now dash lights, no nothing when i turn the key. the 5 pronged plug that plugs into the ignition has 1 plug that lights up my test light but when i turn the key nothing!! Is the ignition bad or is there something else it could be. Just a novice, need help. can start by jumping across solenoid. could it be a safety switch somewhere, how do i check???
  2.
  3. #2
    1,000 Post Club
    bakerg's Avatar
    Join Date
    Mar 2011
    Posts
    1,574
    Location
    Tilbury Ontario, Canada
    Mower
    John Deere D110
    Re: Ignition Switch???????
    Sounds like your switch. When you turned the key off, it should have shorted the coil to ground to stop the engine. Check connection at switch and there mey also be other connectors in line of your wires. If everything turns out good, you may have to replace the switch.
    Kind Regards, Gary
    John Deere D110, Cub Cadet Snowblower
    John Deere H 1/2 scale replica??
    http://s1227.photobucket.com/user/ba...?sort=3&page=1
    Link to Antique Tractor Pictures I've Taken
    http://s1227.photobucket.com/user/ba...24409158903315
Similar Threads
  1. Poulan Ignition switch
    By randomblack in forum Small Engine & Mower Repair
    Last Post: 04-04-2013, 12:55 PM
  2. Repairs Ryobi ignition switch
    By ecruz in forum Mower & Equipment Operation
    Last Post: 04-04-2013, 08:27 AM
  3. Ignition switch problem
    By corrod in forum Small Engine & Mower Repair
    Last Post: 05-29-2012, 07:17 PM
  4. JD gt 245 ignition switch wiring.
    By Thomasam in forum John Deere Forum
    Last Post: 05-16-2012, 06:11 PM
  5. Ignition switch repl.
    By treenerd in forum Small Engine & Mower Repair
    Last Post: 06-02-2011, 09:00 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
