Removing hard water stains
islandboy
We have a good quality kitchen sink that has lime and rust deposits built up by the drain, I have tried everything I can think of to remove the stains, Lime Away, CLR, Ajax, Bon Ami, Clorox, Comet, Iron Out, etc. Every single cleaner fails to dissolve the build up, even when the deposits are soaked overnight. It is possible to chip off part of the deposits using a plastic scraper, but I am not going to use a metal scraper or SOS pad except as a last resort. I have tried WD-40, paint thinner, Goodbye Splatters, Goof Off, all kinds of solvents, nothing will soften the stuff.
HELP, PLEASE !! :confused2:
Try using white vinegar....spray all over the sink then put a layer of paper towels, spray again, leave overnight...next morningi you should see some results ...I have a well , same problem, the vinegar fix works.
Diana Welch
You need to scrape off the rust by using a steel brush before you put any chemicals. It works, I assure you!:cool:
